Engine Revs at the touch of the pedal
Causes for this P0757 transmission code may include:
Insufficient fluid level
Dirty or contaminated fluid
Dirty or clogged transmission filter
Defective transmission valve body
Restricted hydraulic passages
Transmission has internal failure
Faulty shift solenoid
Corroded or damaged connector
Faulty or damaged wiring
Common repairs for this code
Changing the fluid and filter
Repair or replace a faulty shift solenoid
Repair or replace defective transmission valve body
Transmission flush to clean passages
Cleaning corrosion from connectors
Repairing or replacing wiring
Yes it could be as simple as checking the transmission fluid level.
menance
Dec 22, 2010 06:14 PM
beachbum1970
Mar 25, 2009 08:46 PM
