Front Wheel bearing Inquiry
Old Nov 23, 2011 | 03:09 PM
  #31
Originally Posted by anasbio
no I don't have ABS on my car.
I installed ABS bearing on a non ABS car
It was a joke.
Old Nov 23, 2011 | 06:29 PM
  #32
Thanks for that, I spoke to the second dealer service manager, he will check out the HHR on 12-01-2011, he stated he will swap the tires with another HHR they have on the new car lot, just to test the noise and confirm tires or hub bearings, I'll let you know
Old Dec 1, 2011 | 12:08 PM
  #33
I took OldBlue in this morning to the dealersship they just called , both the front hubs are noisy and wwill be replaced under warrenty, they noted the steering column is making someclicking noise but said it is not covered under warrenty, so any suggestions for the steering column like a TSB #
Old Dec 2, 2011 | 05:43 PM
  #34
Put up with a bit of clicking, it's not a safety issue. Mine does it, no play. It is that double U-joint where the shaft takes an 80 degree turn. I'd complain, too!
blacky
Aug 22, 2013 07:23 PM
mcgrosjr
Drivetrain (Excluding Engine)
Apr 24, 2013 11:44 AM
Jeff®
Mar 11, 2013 07:46 AM
STony G
Sep 3, 2012 11:57 AM
OhioPest
Feb 25, 2011 08:52 AM
