Hhr did start but engine stopped
Old May 9, 2021 | 10:01 PM
  #41
ScareDe2's Avatar
The 2.4 is variable valve timing. The 2.2 isn’t. Slightly different bore and stroke. But they share a lot of parts - all the ones you named and more. If the 2.4 is nice, it maybe worth fixing later, so keep it if you can afford the money and space. If it’s not so nice, it might still be worth fixing if you can do it on the cheap yourself, but you probably need to assume r&r for the head and valves in addition to the timing chains. It’s the kind of project a lot of people plan on without actually getting around to doing. If the body and/or the interior are the same color, that’s points in favor of a parts car, but you shouldn’t need that if the 2.2 is nice.
Good luck!
Just bought the 2007 2.2 LS, it is super nice. 90 000 kilo. Was treated every year against rust (although there is very slight rust on the bottom inside door). 2 set of tires winter and summer with lots of treads. Brand new battery and oil has been changed recently. I think I can expect minimal mecanical problems for the next 100 000 kilo. The car might pay itself. I got it for $3500 CAD.
Old May 10, 2021 | 05:12 AM
  #42
Now at that mileage, change the timing chain and balance shaft chain and spark plugs.
preventative maintenance is a lot better than damage to the engine.
Old May 10, 2021 | 08:23 AM
  #43
90,000 kilometers(56,000 miles). Sounds like a good deal!
Old May 10, 2021 | 09:45 AM
  #44
Ok, you can wait till it’s at 100,000 miles, to change the chains and plugs.
Great deal
Old May 25, 2021 | 10:40 PM
  #45
ScareDe2's Avatar
One question. Is it possible to swap the dead 2.4L engine for a 2.2L engine? I see 2.2L engines for sale for about $900 CAD. I think it's not that expensive considering I would have two HHR.
Old May 26, 2021 | 06:50 AM
  #46
The 2.2 2007 did not have VVT , the 2.4 did have VVT , so no that swap is a no go!
Gearhead1
May 3, 2021 04:00 PM
Hotrodbob
11
Apr 8, 2019 12:03 AM
mastersanka2020
Oct 10, 2016 09:13 AM
Work4crown
Apr 9, 2013 12:09 PM
hvrod
2.4L Performance Tech
May 2, 2006 08:51 PM
