Hit a huge rock in road and busted oil and trans fluid pans, car started to sputter..
Old Feb 21, 2023 | 09:01 AM
greg8453's Avatar
Originally Posted by BigBrad75
Like the title says I hit a big ol rock that was right in the middle of the road and I thought everything was fine but then the HHR (2010 2.2l 210xxx miles) started sputtering so I pulled off immediately and shut it off. Had a look underneath and both the oil pan and the trans fluid pan had some pretty good sized leaks, significant enough that they both drained completely within probably 10 to 15 min.
my question is, what caused the car to start sputtering? Is my engine done for? Or will replacing both pana most likely get me back to running like a champ like she was before?
Thanks in advance to anybody whom might have some insight into this situation. I did use the search but couldnt find anything like I'm experiencing? Thanks so much
Drained completely.
When I pulled it over and shut it off it still had a few quarts worth of oil I'd say. I laid there on the ground beside it watching it all leak away. I'm hoping the computer shut off the fuel pump due to the low oil pressure. Makes sense, and that's exactly how it started acting, like it was about to run out of gasoline...
Now it has oil? Did you check the stick? It did not lose but a quart or two? Why did it start running poorly?
Old Feb 21, 2023 | 09:26 AM
The rest of the sentence:
​​​​​​​drained completely within probably 10 to 15 min.
Old Feb 21, 2023 | 09:28 AM
greg8453's Avatar
Doesn't really mean anything if it wasn't measured which is why I asked if he checked the stick. A single quart of oil will produce a huge slick.
This thing didn't start running bad from being a quart or two low.
Old Feb 21, 2023 | 09:35 AM
First before you do anything, see if the engine turns over , either by key or by wrench , the crankshaft bolt is a 21 mm but a 7/8 inch will do in a pinch
if the engine is free and the crankshaft moves, remember turn it clockwise only! Then here a
Proposed parts list,
Engine Oil pan
Permatex black RTV form a gasket
5 quarts 5w30
Engine oil filter
Transmission fluid pan
Transmission pan gasket (GM one, not flimsy thin rubber offshore )
Transmission fluid filter
7 quarts Dextron VI ATF
Old Feb 21, 2023 | 10:57 AM
It means something in the context of the questions asked. i.e.:
Drained completely
and
​​​​​​​Now it has oil?
​​​​​​​The OP question was
​​​​​​​Why did it start running poorly?
He also said he laid on the ground watching the oil drain out after driving a short time, who cares what the dipstick says at that point.
As they say on the TV court shows "asked and answered".
Old Feb 21, 2023 | 11:26 AM
And permission to treat as a hostile witness.
seems to me by the first post, car hit rock, no damages mention about radiator or front bumper fascia, just the oil and transmission pans, it’s mentioned also he watched the oil leak out.
so back to swapping out the oil pan , here’s some tips about the sealant
https://www.chevyhhr.net/forums/prob...t-65895/page2/
a how to for the transmission pan and filter
https://www.chevyhhr.net/forums/how-...hange-58325/oh
Old Feb 21, 2023 | 01:28 PM
greg8453's Avatar
How much time from the hit until the engine stalled or was shut off? I'll get the answer somehow.
Old Feb 21, 2023 | 02:13 PM
Post #7
Old Feb 21, 2023 | 02:49 PM
greg8453's Avatar
Maybe five minutes max. As soon as it started missing a little I immediately pulled over and shut it off
I got my answer.
The engine started having problems due to oil starvation. You best check the internals. Pull the plugs and use a long arm ratchet and turn it over CLOCKWISE. Any noises or issues with the turn?
Old Feb 22, 2023 | 09:39 AM
PulpFriction's Avatar
It's a VVT. As soon as a solenoid valve or a phaser gets starved for oil, it might start to run bad, even before parts start seizing.
Because you shut down quickly, there's a good chance the motor's fine. Keep in mind the chain tensioners also got starved for oil.
hurst2001
Maintenance and Upkeep
23
Jan 24, 2026 07:01 AM
Captron
Aug 14, 2021 01:42 PM
oldracer
29
Aug 16, 2013 12:56 AM
tanker36
Apr 5, 2013 10:58 AM
Lee Wallace
Aug 13, 2009 12:21 PM
