Intermittent power steering problem
Old Aug 22, 2022 | 03:08 PM
We have how to guides for most of the problems.
cruise control can be due to burnt out third brake light bulbs
dead remote fob can be the battery cage is broken just key the words into the search window or send me a pm and I’ll have a look for you.
Old Aug 22, 2022 | 03:26 PM
Shadokat's Avatar
Thank you
Thanks for the info. I don't think any of my brake lights are out but it may be that I haven't noticed yet. Third brake light... I think that's a light in the middle of the tailgate, not on the back corner? I'll have someone check while I touch the brakes inside the car to see if it's out. The cruise control not working has developed within the last three months. I drove to Colorado in May (live in Utah) for a concert (Nightwish, if you're curious) and it was working.
Broken battery cage would mean getting a new remote fob, right? Does a dealer have to do that so it can be programmed to my car?
I'll do a search for both guides. Thanks.
Old Aug 22, 2022 | 03:55 PM
You can solder the battery cage, if your brake lights are working, is there a CEL light on? My cruise control stopped working when I had a CEL problem
https://www.chevyhhr.net/forums/how-...-repair-22641/
another fob fix from our dear friend whopper.
https://www.chevyhhr.net/forums/how-...ontacts-30813/
Old Aug 24, 2022 | 05:56 PM
Shadokat's Avatar
Thanks again, no CEL
Thanks again for this information. I don't know how to solder something nor do I have any equipment to solder with. I've looked at a couple of the solutions people found to repair or replace their key fobs. All of the coding and programming stuff goes over my head. I can't afford the equipment either. I used to build computers when I had a stable place to live and a good job, but most of my tech skills no longer do me any good.
There's no CEL (am I understanding correctly, check engine light?) right now to go along with the cruise control refusing to work. Since I have to have those two things done by a dealer and I have the option to get some auto repair work done free of charge (paid by a grant), I'll probably just ask the dealer to help me even though dealers are more expensive. I've got to get my car back on the road so messing around with DIY solutions that I'm not really good at implementing seems fruitless.
I really do appreciate your time in sending me all of this information! Thank you!
Shadokat
Old Aug 24, 2022 | 06:24 PM
You do not have to go to a dealer for programming.
Dorman has a fob and programming module kit. The fob is less than perfect, but the module will program the vehicle to accept OEM fobs also.
A locksmith should be able to do the job also.
Old Aug 24, 2022 | 07:48 PM
THE most common reason for cruise control failure is 1 or more of the CenterHighMountedStopLight bulbs is blown out
Old Aug 25, 2022 | 12:47 AM
PulpFriction's Avatar
If you you can figure out how to get the tip of a small screwdriver or a similarly-shaped object near red hot you can do the re-solder job. Usually, no additional solder is needed. Some drug users have little torches. Obviously this service will cost you a buck or two.
jimvw
Jun 21, 2022 09:58 AM
jimi
May 6, 2014 02:15 PM
Sundance
Feb 16, 2014 08:53 AM
bthomas515
Mar 14, 2011 11:59 AM
