Like I was out of gas...
Old Mar 19, 2016 | 08:39 PM
HMS's Avatar
HMS
Good to know RJ. Thanks. I suppose the cat might have been soaking up oil. No blue smoke at least. I'll keep a closer eye out for oil drops in the driveway.
Old Mar 31, 2016 | 08:05 AM
HMS's Avatar
HMS
So just as others have suggested, the P0171 code just came back, just as the car has been threatening to stall again when slowing down and downshifting in town. Say, 25-30 to 10-15. If I don't throw it in neutral, I'll stall.
I went to have another look under the hood and found this:
(The link is now pasted correctly for you fine gents).
I don't believe that is factory spec so I reconnected them.
Is that a vacuum line to the MAF sensor? MAP sensor?
Last edited by HMS; Mar 31, 2016 at 11:22 AM. Reason: image was still a link, now it's showing in the post.
Old Mar 31, 2016 | 10:36 AM
I don't even try to open off site pix. There is a link in my sig that will show you the right way to post pics.
Old Mar 31, 2016 | 01:25 PM
HMS's Avatar
HMS
Fixed.
Old Mar 31, 2016 | 01:28 PM
aradmahogany's Avatar
Well connect that hose and bam problem fixed lol.
Old Mar 31, 2016 | 02:29 PM
  #26
That is the PCV hose, it connects to the valve cover. If it is leaking it will cause P0171.
Old Mar 31, 2016 | 06:30 PM
  #27
HMS's Avatar
HMS
Thanks, Don.
Connected it up and the code went away on its own.
Car still runs kinda lumpy sometimes, slowing down in town, but I'll take a small win today.
Where's the MAF sensor? Is that something I should take a peek at?
Many thanks to all.
Old Mar 31, 2016 | 09:37 PM
  #28
on the housing tube from the air cleaner box to the throttlebody housing
Old Apr 1, 2016 | 06:49 AM
  #29
That electrical connector you have to deal with when you remove the air filter.
Old Apr 1, 2016 | 07:39 AM
  #30
https://www.2carpros.com/articles/re...-manufacturers
Some tips, and please use a quality MAF sensor safe cleaner
bigjacksauto
Apr 9, 2012 05:05 PM
bartSS
Mar 12, 2011 11:42 AM
urbexHHR
Mar 1, 2010 10:11 PM
