Lurch/Pulse/Jerking at stop light ?
Old Jun 2, 2016 | 11:57 AM
aradmahogany's Avatar
If that is the case, I am leaning more toward tranny bc I do not typically ever use the A/C unless it is raining or my kids are in the car LOL. Given the frequency that this happens, it must be an electrical or signal issue
Old Jun 2, 2016 | 12:20 PM
Check for burnt or loose ground wires at the transmission ground stud, and loose pins in the connection to the TCM , I'd also suggest checking the fuse box halves , relays and fuses under the hood.
If it is transmission related double check the fluid level.
Old Jun 2, 2016 | 12:41 PM
Thing is, though ,that I have had this issue since day one, and others on the "Lurching" thread have had the issue since brand new. Fluid level is fine as it was changed about a month ago. I think it is just one of those annoyances that nobody really knows is the real cause.
Old Jun 2, 2016 | 01:30 PM
Ok, then , drive on.
Old Jun 2, 2016 | 04:15 PM
The one I linked the guy swore that "resetting the TAP" is what is needed. I remember that from another thread, also.
SwissHHR
Sep 8, 2015 10:47 AM
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
billbryant
Jun 21, 2012 03:51 PM
MOTRV8D
Feb 20, 2008 06:36 AM
