Need Remote Start Help! Please
Hi, I have a 07 hhr 2lt with factory remote start, it has worked fine up till a few days ago now when I go to use the remote start I press the lock button on the remote then hold down the start button and instead of starting the horn honks 3 times and the park lamps flash 3 times. I tried it with engine cold, and hot, made sure all doors and hatch closed 100% and even had a code scanned connected(no codes). Does anyone have an idea whats up? I called the dealer and they said to bring it in, but since im out of warranty at 38k they want 79.99 for the first hour to TRY and diagnos it. I say f'k that.
Thanks in advance for any help or advice
Jason F.
Jason F.
Take a look at this thread.
https://www.chevyhhr.net/forums/problems-service-repairs-42/remote-start-13242/
Post #5
Good luck.
BTW,
to the club...
Sit Down, Hang On, Turn Left.....
OOPS... Wrong club ...
Welcome anyway
Post #5
Good luck.
BTW,
to the club...Sit Down, Hang On, Turn Left.....
Welcome anyway
yeah still no luck, tried new batt. in both remotes = nothing, disconnect battery in car for about 1hour reconnect = nothing, tried turning remote start off then on in dic = nothing. brought to dealer they tried to diagnose spent 3hrs on it and guess what? NOTHING! happy dealer didnt charge me atleast.
so looks like im s.o.l., noone not even dealer can help. meh figures.
it worked fine then just went stupid.
thanks anyways
thanks anyways
Mine is doing the same thing the past two months it works when it wants to..right now it isn't working and both do it. Dealer said they could find NOTHING wrong with it a few months ago. It will be going back in I like my remote start in Maine especially in the winter.
This may be a long shot but check the alarm sensor at front by the hood latch.
May need to reposition. My daughter had the same problem (Cobalt SS) last winter on the coldest days, Turned out the sensor was just far enough away from the latch to cause the no start condition. Moved it up slightly, problem solved. As I said just a long shot, Hope it helps.
But when I hit the remote the to unlock the door the horn honked three times. I looked it up and that is a notification that the vehicle was tampered with, so I agree that your problem may be related to the the hood latch.
HillsdaleHHR
Feb 21, 2009 02:26 PM
