Needing help
You can check your heater core by splicing the 2 heater hose, that willl bypass the heater, if it still acts bad then not the problem.
The weep hole on the pump is on the top in a well. The usual failure is the volute come loose from the shaft (no noise). This is not an old fashioned water pump.
This is one of many on ebay $59.68 The part designation is 2850, that is a fairly standard number.
https://www.ebay.com/itm/2850-New-Ra...rd!22407!US!-1
penning4544
51
Feb 21, 2012 04:01 PM
