Needing help
Old Oct 17, 2018 | 03:55 PM
  #31
You can check your heater core by splicing the 2 heater hose, that willl bypass the heater, if it still acts bad then not the problem.
The weep hole on the pump is on the top in a well. The usual failure is the volute come loose from the shaft (no noise). This is not an old fashioned water pump.
This is one of many on ebay $59.68 The part designation is 2850, that is a fairly standard number.
https://www.ebay.com/itm/2850-New-Ra...rd!22407!US!-1
Old Oct 17, 2018 | 04:02 PM
  #32
Hogbrains's Avatar
Not trying to sound like an idiot , but would the heater core make it run hot ?
Old Oct 17, 2018 | 05:33 PM
  #33
Could cause a sort of air pocket. There is supposed to be a constant flow thru it on the hot side of the t-stat. It flows from the head to the t-stat housing, so cavitation could occur.
1SickHHR
Sep 20, 2013 05:45 AM
penning4544
51
Feb 21, 2012 04:01 PM
foofoomaru
Tires & Wheels
11
Feb 6, 2012 09:15 PM
Archbold
Feb 5, 2012 10:12 AM
