oil filters
Old Dec 12, 2008 | 05:41 PM
  #31
an08HHR's Avatar
I just change the oil in my 08 2LT (1st change) and guess who's name is on it. nope, does not say A/C but HENGST
Web site on Hengst. http://www.hengst.de/conpresso/_rubr...ic=About_us_EN
Old Dec 14, 2008 | 01:11 PM
  #32
wyper01's Avatar
I run Royal Purple 5W-30 and a Purolator Premium Filter,
I change every 7k miles and rotate my tires at each oil change, much easier to remember both that way. I wouldn't imagine changing my oil under 5k miles these days with a synthetic, times have changed and so has technology, the 3k miles idea is outdated and such a waste of money.
Old Dec 14, 2008 | 03:47 PM
  #33
Snoopy's Avatar
^^^^^ SMART MAN ^^^^^^^
Maybe because I think and act the same way you do
Old Dec 14, 2008 | 04:57 PM
  #34
Rcflyboy's Avatar
I stopped by my Dealers and picked up 6 filters for $5.62 each. All had no boxes and were from a bulk shipment. If they are good enough for Chevy than they are good enough for me. Plus if I ever have a warranty issue than they can't use my using another brand against me.
Old Dec 15, 2008 | 01:00 PM
  #35
Fred08's Avatar
Hi, while you are talking about oil filters. I have an 08 2.4 just changed to mobil 1 and a wix57082 oil filter. I noticed that the oil must be leaking down from oil filter as oil is sshowing over full till I start engine and then shut it off and check again I put in five quarts so I know its not over full. Anyone know whats wrong? Thanks Fred
Old Dec 15, 2008 | 01:24 PM
  #36
esmarkey's Avatar
When you change your oil and refill the crankcase, there is no oil in the filter until it runs a few seconds and pumps it into the filter. So, if you check your oil prior to running, the "extra" oil is in the crankcase. After running, slightly less than a quart will be in the lines/filter lowering the amount in the crankcase and thus showing the correct amount.
Does that make sense, or did I confuse you?
Old Dec 15, 2008 | 02:02 PM
  #37
Fred08's Avatar
Thanks for the come back esmarkey, The oil reads good after I shut motor off but the next day it shows over full till I run it again and get the filter housing full. then i shows the right level??????? Fred. Should the filter housing leak down like that if not what is causing it.
Old Dec 15, 2008 | 02:04 PM
  #38
esmarkey's Avatar
sorry, I thought you meant right after you changed the oil.
My understanding is that there is a check valve that should keep this from happening. Not sure if it is in the filter itself or in the block.
Anyone else know this?
Old Dec 15, 2008 | 10:54 PM
  #39
Snoopy's Avatar
See post #23...paragraph 2 of this thread.
Old Dec 17, 2008 | 08:14 AM
  #40
Fred08's Avatar
Snoopy, Thanks for info, went to dealer and purchased filter. Hope it works better. Thanks,Fred08
