P0340 troubles
Old Jul 13, 2022 | 07:08 PM
Antilord's Avatar
Great suggestions if that was my only issue. However the p0340 code that showed up with it points to a signal issue. Trying to figure out which wire color Carrie’s the firing signal from the ICM to ECM. Which also can cause a 2-3 sec extra starter run on. If anyone knows that wire color off the top of their head I would appreciate it. For a different car it’s a brown and white wire at the ICM. I don’t have one of that color
Old Jul 13, 2022 | 07:12 PM
Antilord's Avatar
This is one that I read that has me trying to figure which is the signal wire so I can check it
Old Jul 13, 2022 | 07:58 PM
You say that the wires look odd. Why would they look odd? Wasn't the ICM plug and play? Or did you have to wire it in?
Old Jul 13, 2022 | 08:15 PM
Antilord's Avatar
Was meant to say old. The insulation is dark ish with age and stuck in the form they rested in
Old Jul 14, 2022 | 08:27 AM
PulpFriction's Avatar
Assuming that’s a response to comment #10, dismiss it if you want, but if the wiring to the crank sensor is bad, the car won’t know the car has started, ergo, the starter run-on.
Old Jul 14, 2022 | 09:17 AM
Solution: check all of the wires. The firing signal is generated in the ICM. The ECM receives a "fired" signal.
I suspect the brn/wht wire is the one to worry about. Did you replace the spark plug boots?
Old Jul 14, 2022 | 11:03 AM
Antilord's Avatar
I will check the crank sensor wires today. I put new boots in. Plugs, boots,coil and icm are all new. Thank you for the diagram will check it later as I check others and let you all know what I find.
LarryLarry
Jan 25, 2021 05:48 PM
CHONGO
Oct 17, 2017 11:02 AM
petvetdoc1
Aug 25, 2017 10:33 AM
Paquinr89
Jul 6, 2016 04:47 PM
XtremeModifier
Aug 23, 2010 03:09 PM
