Radio Connections
If you have a factory subwoofer you have the Pioneer Premium speakers. That system has an amplifier behind the subwoofer that powers all the speakers. The means it needs an audio out signal for each speaker. I’m going to guess that each factory radio that was compatible with both the base and the Premium speakers had both a speaker connector for connection direct to the base speakers and a signal out connector for the Premium amp, and that you only connect one of them.
There is however a power out; the pink wire turn the amp on and the antenna amp on. As far as I can tell,maybe wrong, the speaker outs are also the signal outs.
Bahta
Apr 29, 2015 11:43 AM
