Radio Connections
Old Oct 30, 2021 | 04:31 PM
If you have a factory subwoofer you have the Pioneer Premium speakers. That system has an amplifier behind the subwoofer that powers all the speakers. The means it needs an audio out signal for each speaker. I’m going to guess that each factory radio that was compatible with both the base and the Premium speakers had both a speaker connector for connection direct to the base speakers and a signal out connector for the Premium amp, and that you only connect one of them.
Bad guess
There is however a power out; the pink wire turn the amp on and the antenna amp on. As far as I can tell,maybe wrong, the speaker outs are also the signal outs.
Old Oct 31, 2021 | 07:03 AM
I can confirm the radio head unit is the same for the base 6 speakers system and the Pioneer 7 speakers system.
Old Oct 31, 2021 | 05:33 PM
Originally Posted by donbrew
Some radios have a cooling fan, depends on the vendor GM used a few different ones.
Oh, that fan. Thought he was referring to the HVAC fan.
rebelhhr
Dec 4, 2024 10:59 AM
DentedHHR
Nov 17, 2017 08:43 AM
Bahta
Apr 29, 2015 11:43 AM
Kellywren
Apr 23, 2015 01:06 PM
LinkX
Jul 15, 2010 07:00 AM
