Scraping noise when braking
Old Dec 17, 2022 | 04:33 PM
That is a lot more rust than a rainy day.
Old Dec 17, 2022 | 06:13 PM
Do they salt the roads in Maryland?
Old Dec 18, 2022 | 08:58 AM
They used to, I think they have changed to mostly beet juice. I was looking at the rotor, it doesn't look like it has ever turned. 1 rainy day would leave a few spots of surface rust .
I don't know why a professional would say those are good pads, from what I can see they are well into the groove. I guess some shops don't need easy money.
Old Dec 18, 2022 | 09:27 AM
PulpFriction's Avatar
I was thinking the same thing.
It took some thought for me to understand this. My favorite shop does very good work at low prices in a working class community that mostly drives older cars. So of course they’re always trying to catch up with getting their customers back on the road so they don’t lose their jobs. So they tend to balk at doing stuff before absolutely necessary. But if you make an appointment a couple weeks in advance, it seems to provoke less anxiety.
Old Dec 18, 2022 | 02:51 PM
Pads with less than1/16 inch of groove are worn out (period). The groove does more than gauge wear; it is there to help evacuate dust, gases and other crud. Any shop that charges $75 to look at them and doesn't at the least recommend replacement doesn't need income or is irresponsible/incompetent. Saving you a dollar at the expense of safety is not acceptable.
A decent flat rate mechanic can do front pads in 30 minutes. flat rate for 1 axle is about 2 hours including the "test drive/burnishing" that never gets done. And then sell some other work. Not even getting into the $104 MSRP for pads that cost $20.
Granted, there are still people that believe metal to metal isn't quite worn out. I have seen a few that the pads and backing plates had disappeared, and the complaint was "an new noise", the lack of metal scraping.
Old Dec 19, 2022 | 12:20 AM
  #26
Bonez's Avatar
Mine is doing the same only while turning and braking, shop looked at all 4 corners and all are good. I havent looked at them myself yet but just started to wonder if those little retainers are installed? Ill try to get mine in the garage soon and see.... I still have a new set of ACDelco pads sitting.
Old Dec 19, 2022 | 07:01 AM
  #27
Check to ensure the pad anti rattle spring clips aren’t touching the rotors, sometimes you have to adjust them .
Old Dec 19, 2022 | 02:04 PM
  #28
My experience with scraping while turning is bad bearings allow the rotors to tilt and hit the pads.
oldscout
Mar 15, 2015 05:31 PM
asanti
Aug 6, 2010 05:22 PM
Goose
Mar 23, 2010 11:31 AM
Fugazi
Jan 30, 2010 12:16 AM
BlackHHR Music Machine
Apr 21, 2007 08:33 AM
