Service ECS & power steering
Old May 31, 2025 | 10:12 AM
Jim, we’re discussing an SS FE5 suspension here.
The wrong LCAs are a dangerous situation, so fix that first. The steering problem is the way the alignment was done, that threw the steering wheel position sensor off. Fix that second.
Old May 31, 2025 | 10:23 AM
Overkillcustoms's Avatar
Originally Posted by donbrew
A. none of those are Cxxx codes.
B. U2111 should have a hex number after to tell which module (like those Bxxxx have) Basically the steering control system.
C. ALL of those Bxxxx codes pertain to the airbag system, why didn't you mention the airbag light? Specifically one or more elements are disconnected/unpowered.
I suspect someone broke or disconnected a wire while working on the car.
jimvw, as repeatedly stated the SS control arms are NOT the same as LS/LT arms, no matter what a parts book thinks. Almost all books (including GM dealers) claim "fits all".
I forgot that I unplugged the motor assembly to see if it changed anything. I plugged them back in. Ill rescind them. I wasnusing a scan tool that im unfamiliar with.
I UNDERSTAND THE ARMS ARE WRONG. Ill buy new ones if we can figure out this problem. Even though they seem to fit just fine and tighten up correctly. I just don't want to drop thousands into this car to make it "correct" if it doesn't fix the main issue.
Old May 31, 2025 | 10:27 AM
so you are saying that the lower ball joints being the wrong diameter will make my steering angle sensor not work? I understand that I need different arms. Im not driving the car. But if the steering doesn't work I dont want to spend $300 on new LCAs and take the car to the scrap yard.
Old May 31, 2025 | 11:42 AM
I’m not telling you the incorrect ball joints are the cause of your steering angle sensor issues, I’m telling you the wrong ball joints are unsafe.
The steering angle sensor issues are caused by the incorrect procedure to align the front end.
Old May 31, 2025 | 12:00 PM
Here’s a thread about the wrong ball joints damaging the steering knuckle
https://www.chevyhhr.net/forums/brak...knuckle-65818/
Old May 31, 2025 | 12:04 PM
  #26
Just get the ZZP ball joints that Oldblue linked to above at $40 each, no reason to replace the control arms.
OTTP has them also, same price https://www.overthetopperformance.co...LNF_p_295.html
Hopefully your steering knuckles aren't damaged.
Old May 31, 2025 | 01:33 PM
  #27
can you put those ball joints in the new moog arms?
Old May 31, 2025 | 01:36 PM
  #28
I guess I dont understand the procedure. steering wheel is centered and wheels were centered to it. Alignment is true and vehicle tracks straight.
calibration had me. Enter wheel, turn 180 left, then 360 right, then center. Then it failed.
Old May 31, 2025 | 03:07 PM
  #29
Yes you can drill the rivets out of the Moog arms and bolt in the ZZP or OTTP 20.5 mm ball joints.
so, that’s when it failed , try this reset procedure
https://www.google.com/search?q=reca...&client=safari
Old May 31, 2025 | 05:07 PM
  #30
I followed to a Google page that had an HHR and said 90 to left then right. Different than my 180 listed
32VInTechV8
Nov 30, 2023 06:30 PM
brazor06
Dec 11, 2022 07:59 AM
Redbone92
Nov 28, 2012 12:52 PM
HHRNYC
Jul 23, 2009 10:26 AM
tcstoy
Mar 9, 2008 12:50 PM
