service esc
Old Mar 22, 2018 | 07:15 PM
Eric Overmiller's Avatar
when you unplug the maf the car runs good but with no boost with code p0101. when you plug the maf in the car spits and misfires and shuts off. replaced the maf twice, checked for cracks in the intake tube. everything is good on that end. hoping its a boost leak cause i got a Hahn intercooler and piping coming
Old Mar 22, 2018 | 08:15 PM
Like was asked before, what tune do you have?
Old Mar 22, 2018 | 08:43 PM
got a tune from zzp a few yrs ago. even when this problem started, had it sent back to zzp for a retune. even went as far as to getting a new one. still the same. unplug the maf, good but no boost, plug it in. no good. car shuts off
Old Mar 22, 2018 | 08:55 PM
OK, so are you using the stock MAP sensors, or the 3 bar sensors? The lower 3 bar sensor has been known to cause issues when the AC components come into contact with it, as well as poorly crimped, not soldered, connector issue.
Old Mar 22, 2018 | 09:12 PM
Yeah using stock map sensors. Was thinking about upgrading to the stage 1 sensor
Old Mar 22, 2018 | 09:43 PM
Here's a link to a homemade boost leak tester, over at CSS.
https://www.cobaltss.net/forums/how-...ss-lnf-223319/
Old Mar 22, 2018 | 10:07 PM
So, which sensor is the tune made for?
zKabi
May 24, 2017 07:57 AM
dlmhhr
Dec 28, 2013 12:43 AM
Lake Runner
Dec 10, 2012 09:33 AM
esmarkey
19
Jul 7, 2011 12:19 PM
Marzipan
Dec 19, 2008 10:18 PM
