slight ticking noise
Old Oct 12, 2013 | 01:52 PM
rick_rob's Avatar
I have a 2006 2.2 on the one the right side of. The engine I have a slight ticking noise. The car has just over 106,000 miles. In the last week I have changed the belt, belt tensioner, and the timing chain tensioner(ac delco updated one). I have searched on here quite abit, that's why I started with changing these 3 things. It doesn't matter if the engine is cold or hot. Any advice is much appreciated.
Old Oct 12, 2013 | 02:09 PM
Snoopy's Avatar
Probably the fuel injectors, which unless it is abnormally high, is a normal function.
Many threads on this topic!!
Old Oct 12, 2013 | 02:57 PM
rick_rob's Avatar
i have searched that i can only find info on the 2.0 ss engine doing that
Old Oct 12, 2013 | 08:19 PM
All mechanical fuel injectors can make a clickity noise. They are basically solenoid valves that open & close very fast.
But, if you want something to worry about; it could be the timing chain.
You could get a mechanics stethoscope and listen to the injectors, then the chain cover.
Old Oct 15, 2013 | 02:48 PM
malibuhhr's Avatar
Does it tick with A/C compressor on and off? I assume its not your heater motor, they can tick too. What about your alternator, is there debris stuck in it?
Old Oct 15, 2013 | 07:50 PM
Gary B's Avatar
To me, it's any cars that have variable valve timing.
I have three now and they all tick more than my previous vehicles. IMHO
patches22
Jun 22, 2013 01:38 PM
moonsign
Drivetrain (Excluding Engine)
Nov 1, 2012 06:41 PM
eaglefreak138
Mar 30, 2010 06:04 PM
HHRDreaming
Jul 18, 2007 10:35 PM
ssmail8835
Jul 27, 2006 05:36 PM
