Steering bind/Clunk HELP
Old Jul 3, 2019 | 11:19 AM
Kaleb96's Avatar
Thanks everyone, I will have them start by checking the strut mounts.
No I'm not turning the wheel excessively while parked, I do know that puts unnecessary stress on the PS system in any vehicle.
Yes I am most definitely taking it to a different garage. Intermediate shaft checks out fine as well, no sign of binding any of the U joints. I will let you all know if the problem changes or what I ultimately figure out.
Thank you all!
Old Jul 3, 2019 | 12:18 PM
You've replaced all these parts, (I'm especially thinking about the tie rod ends), did I just miss you mention that you had it aligned?
Old Jul 3, 2019 | 12:48 PM
Kaleb96's Avatar
Yes, it was alligned when the suspension parts were replaced.
Old Jul 9, 2019 | 07:47 PM
Lake Runner's Avatar
Not to be a harbinger of doom, but I had similar issues some years back. I replaced the EPS and still it persisted. Found out that the rack and pinion was damaged, probably from the shimmy caused by warped rotors. Dealer repaired because I did not have the time or place to do the work myself. Cost just over $900.
Old Jul 10, 2019 | 07:27 AM
My steering rack was worn out , easy to change, with minimal tools
https://www.chevyhhr.net/forums/how-...ng-rack-58948/
Old Sep 2, 2019 | 06:17 AM
geg's Avatar
geg
Originally Posted by donbrew
NOT wheel bearing the strut mount has a bearing in it.
Have the Lower Control arms been replaced? The rear bushing is a frequent failure, not easily inspected. With the car in park attempt to roll the front tires; if the car moves with the roll they are OK.
Guys - about the strut mount bearing.
I had its size, but I lost it.
Perhaps someone holds this part in their hands or simply knows its inner and outer diameters, as well as its thickness.
Please share the information. Sizes needed.
anthony303
Oct 25, 2018 10:35 PM
mjaxonjr
Oct 10, 2016 09:10 PM
Krunk
Oct 21, 2013 07:52 AM
dustymulette
May 29, 2012 08:03 PM
BeanWagon
Feb 3, 2012 03:42 PM
