steering problem
steering problem
I have a 2006 hhr. I am having problems with steering. I replaced the fuse in the engine fuse block because it was blown. I checked the fuse in the floor console and it is ok.I am also having problems with the climate control. I can hear the fan blowing but nothing is coming out hot or cold. I tried to see if the air conditioner would work, no luck. This all started when my car would not start and I tried to jump start it. I had to replaced the battery and have
had problems ever since. Please Help!!!!
Could you have possibly tried to jump start it incorrectly? Maybe by connecting to what you thought was a positve or negative terminal under the hood. One terminal with a red cap AND NEAREST TO THE FIREWALL is NOT a jump start terminal. Could you have used this??
