steering wheel question
Old Aug 19, 2016 | 07:43 PM
I had a ball joint on a new LCA last less than a year.
Old Aug 19, 2016 | 07:59 PM
Same here. It put the steering wheel out of line pretty good but otherwise I didn't feel any problem at all.
Old Aug 21, 2016 | 10:53 AM
87z16's Avatar
well you guys are correct again!!!
brakes appear just fine.
looked at the passenger side LCA. the bushing with the 2 bolts appears to be frayed, tightened those 2 bolts about say 1/4 turn. the long bolt is nice and secure. then i checked the rear bushing and it appeared cracked. i compared it to the drivers side. yup the pass side is broken in a few spots. I took a pic but i am having issues posting it.
guess i will be redoing the LCA's. these should be done in pairs, correct???
THANK YOU!!!!!
Old Aug 21, 2016 | 11:56 AM
There is a link in my sig "How to upload and post pictures".
Old Sep 5, 2016 | 07:04 PM
87z16's Avatar
well i changed them both. glad i did the other started to break up as well.
car came with the aluminum lca's and when i first swapped them out i put on the stamped steel units from mevrotec, ill never use them again. and this time i put back the aluminum lca's from MOOG.
i hope they last a bit longer.
thank you everyone for steering me the correct way!!
OH YEAH now my steering wheel is ****ed over to the right?!?!? is there a way of straightening it??
donbrew i will look over your suggestion of how to post pics and i will.
Old Sep 5, 2016 | 07:25 PM
Only adjustment to center up the steering wheel is the toe on the front wheels.
In other words....alignment shop.
Old Sep 5, 2016 | 07:37 PM
The reason the steering wheel is now off center is because it was aligned with bad parts. So now the alignment is way off.
If you want to cause a lot more problems you can pop the wheel off and recenter it. I found out that is a bad idea.
CorvetteMongo
Mods - Interior
Mar 20, 2016 10:20 AM
GiasDaddy2010
Jan 12, 2014 03:55 PM
RStruthers
Jul 7, 2012 10:50 AM
bwhite757
10
Feb 26, 2010 07:01 PM
Black Rose
Jun 7, 2007 06:47 PM
