steering wheel question
well you guys are correct again!!!
brakes appear just fine.
looked at the passenger side LCA. the bushing with the 2 bolts appears to be frayed, tightened those 2 bolts about say 1/4 turn. the long bolt is nice and secure. then i checked the rear bushing and it appeared cracked. i compared it to the drivers side. yup the pass side is broken in a few spots. I took a pic but i am having issues posting it.
guess i will be redoing the LCA's. these should be done in pairs, correct???
THANK YOU!!!!!
THANK YOU!!!!!
well i changed them both. glad i did the other started to break up as well.
car came with the aluminum lca's and when i first swapped them out i put on the stamped steel units from mevrotec, ill never use them again. and this time i put back the aluminum lca's from MOOG.
i hope they last a bit longer.
thank you everyone for steering me the correct way!!
OH YEAH now my steering wheel is ****ed over to the right?!?!? is there a way of straightening it??
donbrew i will look over your suggestion of how to post pics and i will.
The reason the steering wheel is now off center is because it was aligned with bad parts. So now the alignment is way off.
If you want to cause a lot more problems you can pop the wheel off and recenter it. I found out that is a bad idea.
GiasDaddy2010
Jan 12, 2014 03:55 PM
RStruthers
Jul 7, 2012 10:50 AM
bwhite757
10
Feb 26, 2010 07:01 PM
