Take a look at my fuel pressure test?
No, if you replaced the part in the Rockauto site as per your link, the part you replaced IS the Camshaft Position Sensor as per the listing in RockAuto - their listing is not wrong.
You called it a Camshaft Position Actuator Solenoid - but it is the above sensor.
Camshaft position sensors are on the front and back sides of the engine. Camshaft VVT valves/actuator solenoids are on top of the engine. Camshaft position actuators/phaser is on the camshaft.
The sensors tell the ECM where the cams are. The valves/solenoids tell the actuators where the ECM wants the cams to be. The actuators/phasers retard/advance the valve timing.
I am mystified as to why anyone would try to blame the camshaft itself for a position error.
