Temperature running hot
Old Oct 12, 2010 | 08:39 AM
tech-guy's Avatar
I am now shocked.. I checked the Over flow tank last night and there was no water at all anymore... I remember I added a little more than 1/2 a gallon of water and now its all gone.. I fill it up again last night with Anti freeze and I will see now how long that will last. Sof far no leaks no white smoke and oil is perfect no water in oil either. So any suggestions as to why the water is missing? The car also no longer over heats the hotter is has been is 196 degrees and in the freeway is 189...
Thanks
John
Old Oct 12, 2010 | 10:13 AM
pitbull76's Avatar
It could still have a slow internal leak. I had a GMC Sonoma once with the 2.2L that had a leaky head gasket. No water in the oil, and you couldn't see white smoke but it was using antifreeze.
Old Oct 12, 2010 | 12:41 PM
tech-guy's Avatar
How can I figure out if it has a leaking head gasket?
Thanks
John
Old Oct 12, 2010 | 01:13 PM
pitbull76's Avatar
Thanks
John
Since you have a 2009, it should at least be under the powertrain warranty. I would get it checked at the dealer really. They will do a pressure test and/or look more closely for external coolant leaks. The main downside is if they find it is something simple you may be on the hook for the repair, but if it is internal your powertrain warranty should cover it. If you have less than 36K miles, take it to the dealer for sure as it would be covered no matter what the leak is.
Old Oct 12, 2010 | 01:19 PM
I also noticed that when I was adding more water to the over flow tank for the most part the water was draining. I guess the over flow tank has some sort of orifice where it does not allow the tank to be filled to the neck part.. Is that normal? Also the car has not over heated eversince.. I will continue to monitor the car....
You mentioned it was leaking out of the overflow tank (or expansion tank) the first time you added fluid - this last time you filled it, did it leak onto the ground? Was the hose at the bottom secure and not leaking?
Old Oct 12, 2010 | 01:20 PM
Good advice.
Old Oct 12, 2010 | 02:44 PM
tech-guy's Avatar
No it was not leaking at all this time that I added more fluid to it..Now I can see the anti freeze in the over flow tank and it has not lower any bit eversince last night...
Thank
John
Old Nov 3, 2010 | 09:25 AM
tech-guy's Avatar
I took it to the dealer they did a preassure check and found no leaks at all. SO far it has been running fine for the past 3 weeks... the water level is fine and also the gauge us fine so I am thinking for some odd reason it needed water...
Thanks everyone for all of your help...
John
gio89kid
Maintenance and Upkeep
25
Mar 15, 2015 12:15 PM
DaveEast
Mar 5, 2015 11:54 AM
Restlessone
Jan 1, 2015 06:35 PM
Ponyman1
Sep 6, 2009 06:12 PM
budzone
Jan 23, 2009 09:50 PM
