trans issues
Old Feb 19, 2014 | 09:23 PM
outlaw's Avatar
I have checked the fluid, it was only about a half quart low. It does seem that the pump is making noise. I have found a transmission locally with only 47,000 miles on it for 400. Thats the route im gonna take.
Old Feb 21, 2014 | 10:24 PM
Just to be sure; you checked it car level, engine running, ATF temp 104F, trans in park or neutral.
How would you be able to know a half quart low? There is no dipstick! only the port for "full-not full" it's digital not analog.
If nothing came out the hole with the engine not running, the thing is empty.
Old Mar 3, 2014 | 09:56 PM
cc732's Avatar
I think outlaw is on the right track...no forward pull in 1st gear indicates a problem with the forward clutch. The pump noise and low fluid level sounds to me like someone has tampered with the trans.(forward clutch is not properly installed, or a cut ring seal on the forward clutch support.)
Dexron V is in my '06 6FW trans@ 60,000 miles in 8 yrs it's still fine.
Good Luck with the replacement trans. I would go with a "certified rebuild".
Clare
LuckyLadySD
Jun 12, 2014 02:09 AM
Jakeitb
Drivetrain (Excluding Engine)
Mar 22, 2014 07:24 PM
Bkm0607
0
Sep 14, 2012 12:49 PM
10RedSS
Oct 25, 2011 09:16 PM
