Transmission Coolant Lines filled with Oil
Old Feb 10, 2024 | 03:15 AM
  #41
Andrew_rogers's Avatar
Reply
Originally Posted by Oldblue
X2^^^^^^
If the transmission cooler in the radiator had failed there would be coolant in the transmission and transmission fluid in the radiator
Yeah radiator for sure is my guess… the thermostat was failed when the boil water plop test did just gotta Camry with same thing it seems to be the main issue with Facebook cars, radiator or time chain, though was doing this thing on the highway started bucking with loss of compression the HHR so the first place as beginner mechanic was the major issues for loss of compression though should have known from the way the engine was freaking out that it was pressure build yet had no overheating warning so failed sensor yet no show on the code pull? IDK…
Old Feb 10, 2024 | 03:19 AM
  #42
Reply
I’m thinking that last bolt on the top to our left isn’t all the way out. I remember someone else had this issue awhile back.
yeah was the bell thought it was the axles needing to be pulled cause they attach different then typical? got it off the flywheel with the four bolts! Took everything apart hit it with Dawn Platinum Spray which works great and piece by piece in the dishwasher so can give it a ceramic paint(maybe) and work on getting it back in with new lines and wiring and piston and etc !
Old Feb 10, 2024 | 03:27 AM
  #43
Reply
Lots of odd things going on in this picture. Cut wiring. Loose, partially separated transmission casing. Cable bracket under the casing ?
My copy of the pic may be a little blurry so also look at the OP's original above.
https://www.chevyhhr.net/forums/atta...1&d=1707060863
Dude don’t ask 😆 it looks prettier now though for sure
clean and stored waiting to run through the transmission maybe slap it into a buggy frame IDK cool engine and transmission for sure. Though yeah was doing everything wrong cause broke down and attempted to do this @&$! Like 3 blocks from home in freezing weather in parking lot for sure had its effect on outcome.
Old Feb 10, 2024 | 03:30 AM
  #44
Reply
Originally Posted by donbrew
How is it possible that it ran good for 3 weeks with no cooling?
Im in question also the same thing failed sensor maybe? Cause I was not on the highway with it so…
Old Feb 10, 2024 | 03:33 AM
  #45
Reply
Did you remove the torque converter bolts?
I thought I could separate transmission to unbolt it for a minute as it was actually pinching as so the stress from uneven floor engine lift not allowing crank to rotate and get at the bolts.
Old Feb 10, 2024 | 03:34 AM
  #46
Originally Posted by oldblue
it’s a good mystery novel, but no joy in finding out what is the problem .
Old Feb 10, 2024 | 07:31 AM
  #47
And so are you fixing the HHR? Replacing the engine? Rebuilding it or selling it?
Old Feb 10, 2024 | 07:44 AM
  #48
If there was NO cooling, as in full blockage the engine would only ryn for about 20 minutes before it seized. First, all of the oil would burn off then the bearings and pistons melt. It is not air cooled.
That is why I call B.S.
will1528
Jul 21, 2021 05:06 PM
Jefferey Mariner
27
Jan 12, 2016 10:44 PM
seren89
2.2L Performance Tech
Feb 2, 2015 12:03 AM
lil tank
Dec 30, 2013 08:57 PM
1900colt
15
Nov 16, 2012 10:54 AM
