want to put bluetooth in my 2011
Old Jan 18, 2023 | 04:08 PM
felcan's Avatar
vcim part #
looking up part #,s for the 2011 for the vcim that has the bluetooth ( UPF ) it is a different part # 22867076 and the one I got from the wreckers is from a 2010 ss with part # 22835668 . Does anybody know if I can use this one before I install it as I do not want to screw anything up .....tia
Old Jan 18, 2023 | 04:24 PM
This doesn’t seem to fit your 2011
Same here , but Read post #2 and and the rest of this thread
https://www.chevyhhr.net/forums/audi...-module-46672/
Old Jan 19, 2023 | 04:17 PM
felcan's Avatar
2011 finally bluetooth connected
ok here is what I finally did to get bluetooth in the car .......first change out the right hand side on steering wheel with controls that have phone/mute button on it .....it is just a plug in on the wiring that is there......Next find a communication interface module Assembly ( with mobile phone Transceiver ) the one I got from the wreckers was out of a 2010 hhr ss...part # 20833261......there is little ridges on the antenna connection that do not match up with the plug ....on the module that was in the 2011 had them orientated at 7 and 11 o clock and the one from 2010 hhr have them at 5 and 11 o clock. I grind ed the 5 o clock ridge off with a file and then it was just plug the harness,s in the module and voila ! everything worked.... lots of plastic panels to remove on passenger side
Old Jan 19, 2023 | 08:25 PM
Awesome, problem solved!
Old Jan 19, 2023 | 08:50 PM
You know it is phone only profile, no music.
Old Jan 19, 2023 | 09:16 PM
You said it in post #6, so they should know this.
Old Jan 20, 2023 | 06:31 AM
At least the Bluetooth works, even if it is just for phone calls. I’m old school, I ignore my phone when I’m driving, it can wait!
Old Jan 24, 2023 | 11:46 AM
PulpFriction's Avatar
Detail from a 2011 LS window sticker:
Old Jan 24, 2023 | 04:14 PM
Nice from a 12 year old car. But it’s proof , BT is phone calls only
MikeG.
Dec 6, 2018 02:10 PM
Ron S
Nov 14, 2016 06:02 AM
isa1014
Mar 8, 2014 05:40 AM
joeypete
Jun 16, 2011 10:45 AM
