Water on floorboard
Old Sep 30, 2009 | 09:44 AM
an08HHR's Avatar
Originally Posted by Jeff'sHHR
Check to see if you cabin air filter is wet.. If it is then you problem is just above it.. The cowling cover at the base of the wind shield, directly under the windsheild wiper..You need to remove that cowling and under that, just below the passenger side wiper is a seal thay may have failed. If you remove that seal you can see right down into the cabin filter.. Take it to a dealer if you can't do it and make them look under there. That maybe your problem ...Jeff
I'm a few days late on this on. THE 08's and after don't have this same design as the 06' and 07's. There is no rubber boot on the new design and you can see the fan so don't panic.
HHR911
Jan 26, 2013 07:47 PM
daddy2isaiah04
Mods - Interior
10
Dec 20, 2012 04:07 AM
linmoody
Sep 20, 2010 08:19 PM
jonboyb
May 17, 2010 03:53 PM
tcstoy
Sep 13, 2008 08:55 PM
