Weird Issue
Old Aug 26, 2024 | 11:05 PM
Shakes's Avatar
Weird Issue
Driving my 08 2.4l home tonight temp gauge and ac quit working.
After searching and reading and looks as if the tstat is bad and I need to replace with ACDelco 131-158.
Going to do so in the morning, what I keep questioning in my mind is, shouldn't it have thrown a code or CEL? isn't the CEL what disables the ac? Got me wondering if there is something else going on?
Old Aug 27, 2024 | 07:18 AM
PulpFriction's Avatar
Not nearly enough information. No CEL? Have you scanned for codes? Did the temperature light come on? What is the temperature reading in the DIC? Have you checked the coolant level both in the recovery tank and under the pressure cap? Has the thermostat ever been changed before?
A bad thermostat, depending upon what’s wrong with it, usually causes a variety abnormal coolant temps, not a null gauge reading.
Old Aug 27, 2024 | 07:39 AM
Shakes's Avatar
I did scan for codes, there were none. Temp light did not come on. No temp reading in dic just a couple dashes. Have only owned car two weeks so have no idea if stat was ever changed. Coolant levels were fine.
Old Aug 27, 2024 | 07:42 AM
Pulp
It’s well known that when the thermostat fails and the coolant doesn’t heat up in the required time frame, you may lose the temp reading and AC function.
The OP stated that is what happened to him.
I think this must occur more than one time to trigger a CEL. (P0128) The no temp reading will display dashes (- - -) in the DIC.
Old Aug 27, 2024 | 07:48 AM
I concur with FMG , new thermostat and fresh Dexcool
Old Aug 27, 2024 | 08:00 AM
No loss in making sure it has the correct thermostat, so I would do it anyway.
But the DIC should show the temp immediately upon startup. I think there's a problem with the temp sensor.
As the age of the coolant is unknown, and likely very old, just dump the cooland, taking the opportunity to swap in a new thermostat and temp sensor, and fill with new Dexcool.
Cheap and easy. If still no reading, likely wiring.
Old Aug 27, 2024 | 08:06 AM
He said the temp reading quit while driving. Nothing was said about it not working at startup. Don’t confuse him. It’s almost certain it’s a thermostat issue.
Old Aug 27, 2024 | 09:44 AM
Shakes's Avatar
Changed tstat, decided to do temp sensor at same time, new one snapped off. F*ck!!
Old Aug 27, 2024 | 10:06 AM
Shakes's Avatar
Was able to get new temp sensor our with screw extractor, thank God!! Put original back in and everything working again as it should.
Old Aug 27, 2024 | 10:55 AM
Awesome! Enjoy the drive! And burp that Dexcool!!
https://www.chevyhhr.net/forums/how-...-system-60614/
quicksilver58
Dec 2, 2015 08:43 PM
Grandpa22
Mar 27, 2015 12:58 PM
rad1steve
Sep 11, 2014 05:10 PM
jay loukakis
Feb 22, 2013 06:52 PM
HipHotRod
Aug 5, 2011 02:45 AM
