Wont start 08 hhr
Old Feb 22, 2016 | 12:14 PM
Steven&kristina's Avatar
Wont start 08 hhr
We has this vehicle a month. Tried to put a audio system in.with a amp new radio and speakers.unsuccessful.we blown fuses.replaced them.tried the 30 min relearn because the car wont start.it clicks like it wants to turn over.like a him noise.battery is good.is there something I'm over looking? Something I'm missing? Is there a easy fix? Do you think I should call the dealer ?
Old Feb 22, 2016 | 12:57 PM
Moved your entry to the Problems/service/repairs area.
My first thought is it is the battery is too low a charge. It sounds like you used a fair bit of the battery when installing the audio system (blowing fuses etc.). But you say the battery is good - how do you know it's good? What is the voltage reading directly off the battery? If it's charged it should be 12.6-12.7V.
the battery is pretty small in the HHR, and does not take well to being drained even for a short while - ie: a half hour to an hour will often drain it pretty bad, depending on what you are doing (even with the doors open, and lights on)
See this for a breakdown on the voltage vrs charge: https://carbatteryworld.com/car-battery-voltage/
Old Feb 22, 2016 | 01:00 PM
Welcome to the site, please elaborate in your new radio, it is possibility the anti theft has the ECM thinking someone stole the car.
Did you use any harness adapters or just cut into the harness?
Butchjr
Nov 17, 2015 06:20 PM
Nicole N.
Sep 6, 2015 08:51 PM
hhrrat
2.2L Performance Tech
48
Dec 24, 2014 08:47 PM
PaperChaseHHR
Nov 18, 2014 03:19 PM
IowaHHRGuy
Feb 3, 2009 09:57 AM
