XM radio
Old Jun 29, 2010 | 06:57 PM
Nurseman27's Avatar
XM radio
I just got a 2008 HHR LS 30,000 miles I was wondering how i could get the factory XM set up replace radio with one that is got it? I have on star so i have 2 antanas on the top one in front and one in rear is this something i can do fairly easy? has any one done this?
Old Jun 29, 2010 | 07:09 PM
ChevyMgr's Avatar
As long as you have RPO Code UE1 and don't have U1C you can add the module below. RPO Code list is located in the glove box.
XM Radio Upgrade Kit. Part Number: 17800594
Old Jul 19, 2010 | 09:13 PM
JUSTKEV's Avatar
I just got a 2009 HHR 2LT and want to add XM radio to it. I have installed one in my 2005 Trailbalzer that I got on ebay with no problems. I want to install the same kit in this HHR and want to know if it will work. The kit says it will work with or without OnStar. I emailed the seller(whom I purchased my trailblazer kit from) and they said that it will not work UNLESS you have OnStar. I DO NOT have OnStar so I am not sure. I dont care to have the antenna in the back of the roof, I can just hide the antenna wire and run it to the top of the roof. So I want to know if the plug and play kit will work with my HHR without OnStar. I also have the correct radio for this to work. THe RPO Code is UE0 as listed in my glove box. Someone please give me a clear answer if you can. Here is the link for the ebay auction.
http://cgi.ebay.com/ebaymotors/2006-...fAudioQ5fVideo
Thanks,
Kevin
Old Jul 20, 2010 | 12:36 PM
ChevyMgr's Avatar
Originally Posted by JUSTKEV
So I want to know if the plug and play kit will work with my HHR without OnStar. Kevin
Sorry it won't work. You must have OnStar.
Old Dec 10, 2010 | 10:12 PM
Nurseman27's Avatar
thanks for all your help
I still have not found the RPO code i do have onstar if i have the code good for xm how hard is it to add the kit? how much would this cost?
Old Dec 10, 2010 | 10:18 PM
Look for the RPO codes in the glove box, its a label pasted in there, kinda hard to read so grab a flashlight.
Old Dec 10, 2010 | 11:09 PM
Blue Lightning's Avatar
Thanks,
Kevin
?????? Maybe I missed something because I would've thought it would already be there (as far as the wiring is concerned) and all you would need to do is activate it. I have a 2009 2LT as well and it came with Onstar (I bought it brand new in 2009 and I still have it activated). From what I remember the 2LT is already Onstar ready (at least it seems they were for 2009 and a year came standard with them) so if you bought it used, all that needs to happen is for you to pay the fee and activate it. Anybody want to jump in on this cause if I'm off base, I apologize in advance. I would think again that the wiring is already in place. For example, if I were to trade mine in for an SS, the Onstar activation might run out by the time someone else bought mine but the wiring would still be there.
Blue
Old Dec 11, 2010 | 03:06 PM
Sno White's Avatar
The wiring (and module) is probably not there – GM, as well as all manufactures, are trying to save weight and thus increase gas mileage. So nothing extra is added to vehicles anymore.
It is possible Kevin’s vehicle was a fleet or rental vehicle and thus was not equipped as such. My base level 2009 LS came with both XM and OnStar – both of which I have switched off.
Also see:
https://www.chevyhhr.net/forums/show...9&postcount=11
for that "UE0" RPO code.
Clearly states: "UE0 Communication System - Vehicle, G.P.S. - Not Installed"
Krusty
Jun 9, 2012 02:45 PM
capp002
Oct 18, 2011 02:24 PM
SargeRN
Oct 5, 2011 08:21 AM
Sno White
"How To" Tutorial Library
11
Aug 26, 2009 05:48 PM
KY Dave
Jul 26, 2006 04:27 PM
