Apparatus Bolted to Intercooler
Old 04-04-2019, 11:27 AM
DrLoch's Avatar
They also don't have to worry about powertrain warranties though.
DrLoch is offline
Old 04-04-2019, 12:28 PM
But, then again theirs are aluminium, not aluminium and plastic bits bolted together
Oldblue is offline
Old 04-04-2019, 12:45 PM
m_ridzon's Avatar
In terms of the powertrain warranty, I think @DrLoch is referring to the problem of the intercooler becoming a collector of oil and/or water contaminants that may later be ingested into the engine, leading to warranty claims.
m_ridzon is offline
Old 04-04-2019, 01:01 PM
DrLoch's Avatar
Originally Posted by m_ridzon
In terms of the powertrain warranty, I think @DrLoch is referring to the problem of the intercooler becoming a collector oil and/or water contaminants that may later be ingested into the engine, leading to warranty claims.
Correct
And if there is an issue they will only replace their product, not all the other damaged items their product may or may not have contributed too. Like the picture I posted showing a piston with a piece of a valve stuck in it. The valve spring manufacture admitted that they had an issue with some valve springs, they offered to replace the valve springs. The motor that was destroyed because of the valve spring failure was worth in excess of 80K, not much was salvageable, vibration damper and blower pulleys. This was early 90s dollars.
DrLoch is offline
Old 04-04-2019, 03:06 PM
Cat Man HHR's Avatar
Originally Posted by DrLoch
winner winner Pretzel is correct
Ditto
I'm the stupid guy from before.
Cat Man HHR is offline
CGYHHRSS
"How To" Tutorial Library
08-14-2009 08:29 PM
turbo wanabe
2.0L Performance Tech
51
09-14-2008 08:54 PM
c2vette
05-26-2008 10:13 AM
jonboyb
04-22-2008 11:17 AM
Quick Reply: Apparatus Bolted to Intercooler
