Cam Solenoid Issue
Cam Solenoid Issue
I have a TC & ABS light on constantly (08 SS 5-Speed) that was intermittent for a year. Got a Cam Position Sensor code a few times, but It has not come back. There are no ESC or ABS codes. I replaced the front wheel bearings w/ABS sensors, as I have seen this be the issue on other vehicles, but no change. I read the Cam Solenoid thread & it looks like this might be my problem too, but most of the posts were for Automatic Trans. cars. Is the issue the same for 5-speeds also?
Thanks!
Thanks!
Yes, but with automatics, the trans shifts rather abruptly which can really be quite alarming to many people.
If you are looking for further advice, you really need to post the code generated by the OBDII system - if it isn't generating a code, any advice would be a total guess. Problems with the Cam Actuator Solenoids will generate the infamous p0010/11/13/14 codes - and they generally will be created if those specific parts are having problems.
If you are using a basic code reader, they generally do not read the more detailed ESC/ABS codes - for that, you will likely have to visit your local Chevy dealer who will use their more advanced readers (tech II).
Thanks!
Thanks!
Reread the 3rd paragraph of whopper's post above.
And to echo the other thing whopper said, if you don't post up the original trouble code number you had, it's a little hard to try and help you. We would be just taking guesses.
2007HHRLT
02-08-2013 07:17 PM
