Coolant leak somewhere
Old Dec 15, 2022 | 10:06 AM
  #91
At least the head gasket is above the water pump!
  #92
A simple compression test should reveal if the head gasket is bad.
Old Dec 15, 2022 | 10:07 AM
  #93
But would not show a coolant leak!
Old Dec 15, 2022 | 10:15 AM
  #94
If the coolant is leaking into the cylinder, it would. But if it's leaking between a coolant passage and an oil passage, then, no. I think it would be wise to check, since he's not planning to change the head gasket at this time.
Old Dec 15, 2022 | 10:42 AM
  #95
hhrumadbruh's Avatar
I got back there with a mirror and a camera and could not pinpoint the leak. I think it would be odd for the head gasket to leak exactly at the part of the engine where the water pump is!
Old Dec 15, 2022 | 11:02 AM
  #96
Have not heard anyone mention the engine block porosity problem. This was an issue with some of the 2008 SS engines.
Doubtful but another thing to check on. Especially since you can’t seem to locate the leak.
Old Dec 15, 2022 | 11:55 AM
  #97
From the top of the block see the water jackets, over on the left by the water pump. Possible leak area
Here’s a look from the water pump mount side , it could be the gasket just above the round hole where the water pump bolts up!
With the water pump bolted on no you can’t see much , however the cylinder head does sit just above the water pump, you should be able to see better once the pump is removed
Old Dec 15, 2022 | 12:47 PM
  #98
Thanks for the pics. No wonder I can't find the source. Its hidden back there. Hoping its the water pump or gasket!
I should be able to tell after I've replaced the pump and gaskets.
Old Dec 15, 2022 | 01:03 PM
  #99
Make sure you clean those surfaces the water pump gasket contacts.
Old Dec 15, 2022 | 01:10 PM
  #100
To get the bolt out from between the heater lines, you must remove the coolant temperature sensor, this photo is upside down
Here’s a photo of the block side and the strange oring that becomes square when you install it.
