Coolant leak somewhere
Old Dec 22, 2022 | 02:57 PM
  #101
hhrumadbruh's Avatar
All the parts came in yesterday!
Going to start on it today.
Old Dec 22, 2022 | 06:45 PM
  #102
Anyone know how to get this thing off so I can remove the valve cover? Already got the bolt out but its not coming off.
Old Dec 22, 2022 | 07:25 PM
  #103
If I remember, it just comes straight out, there's an O-ring around a tube.
Old Dec 22, 2022 | 07:53 PM
  #104
Got it. Just had to pull a bit. It was a pretty tight fit.
Took the valve cover off, did some cleaning.
Propped up the motor via block under the oil pan and removed the passenger side motor mount. Got it up a decent amount.
What do I need to take off next?
Old Dec 23, 2022 | 07:17 AM
  #105
The harmonic balancer bolt, then the serpentine belt and tensioner, then the front cover.
That will get you access to the chains. You will have to lower the engine to get the long water pump bolt out!
Old Dec 23, 2022 | 01:43 PM
  #106
lower as in lower than stock height?
Old Dec 23, 2022 | 01:53 PM
  #107
Forgot to order new camshaft sprocket bolts. I wonder if napa or AutoZone would have them?
Old Dec 23, 2022 | 02:18 PM
  #108
Lower than stock, just to get that one bolt out.
min a pinch you can reuse the camshaft bolts and the crankshaft bolt.
Old Dec 23, 2022 | 02:20 PM
  #109
Orielly said I could have new camshaft bolts by 3pm so I'm gonna do that.
What/where are the crankshaft bolts?
Old Dec 23, 2022 | 02:25 PM
  #110
This one it’s a 21 mm use a pry bar or large screw driver to hold the harmonic balancer to loosen that bolt.
