SS Specific Service Issues/RepairsService/Repairs specific to the SS. Turbo-Brembo Brakes-2.0 Engine-Limited Slip Differential-Programmable Display-MU3 Transmission
I see you didn’t time the crankshaft and camshafts, so to avoid bending any valves , remove the camshafts, keep the parts and bolts in order, the rotate the crankshaft until the #1 piston is at TDC , the keyway will be at 12:00 o’clock and the dot on the sprocket will be at 5:00 o’clock.
putting it back together is the same as this 2.4 , reuse your crankshaft sprockets , they are different in the 2.0
I've got the 4 bolts on the water pump off but can not remove it. Its been leaking a lot so there is no coolant in it anyway. I just don't know how to get to the thermostat to allow me to remove the water pump.
as far as the bolt, which one are you referring to?
the video i watched said to put the camshaft sprockets at 10 o'clock and 2 oclock. And the crankshaft keyway at 12 o'clock. So that's where they are at. Is this not correct?I did this before removing the chains. I have not touched the other sprockets that require a punch or drill bit to lock in, as I didn't see a need for that.
Read the DDM link I posted, for visual purposes it has photographs of the entire reassembly, look at the cam Phizer sprockets one shows INT the other EXH
