Coolant leak somewhere
Alright got it running...started and idled great. Noticed it got up to about 107°F as it sounded as if the pistons were about to sieze so I shut it off. Some light smoke coming from oil spout on the valve cover. Checked the oil with the dipstick and its bone dry. I just put 5 quarts in it...Im guessing something is plugged in the engine relating to the oil.
Did you clean the oil pan? Clean the oil pump in the front cover? Any oil puddles under the car?
Did you burp the coolant?
https://www.chevyhhr.net/forums/how-...e-items-54648/
Need another engine. I wouldn't waste my time on that one. Fix one thing and something else will fail.
That much crude in there will plug up oil passages and galley's. Next will be oil pump then rod and main bearing failure. And I'll bet the turbo is on it's last leg if not shot.
