Dirt in camshaft solenoid?
Old Dec 24, 2023 | 11:21 AM
If the code is P0011 or P0014 you can try cleaning the screens with your choice of oil solvents. Sometimes it works.
If it is P0010 or P0013 check wires first otherwise replace valves.
Old Dec 24, 2023 | 11:35 AM
hhrumadbruh's Avatar
Originally Posted by Oldblue
Thru the oil gallery to the oil pan then back up thru the oil pump
I believe through the oil pick up tube in the oil pan as well? should I look into the oil pump and oil pick up tube? How hard are those to get to?
Old Dec 24, 2023 | 11:38 AM
its a p0014 code. It went away when I swapped the exhaust solenoid but seemed to pop back up a week later. Not sure if its because it got a little dirty again. But I will check them both in a week and keep cleaning them out.
Old Dec 24, 2023 | 03:49 PM
PulpFriction's Avatar
I'm looking at the diagram FMG referred to, and it never before occurred to me that the junk on the screens could come from the phaser. Any seals inside those?
Old Jan 6, 2024 | 07:14 PM
What is the phaser??
Old Jan 6, 2024 | 07:28 PM
It's what you might call the camshaft sprocket.
Old Jan 6, 2024 | 07:39 PM
The VVT sprockets on the top?
Old Jan 7, 2024 | 07:53 AM
I think you should remove the valve cover and look for slack in the timing chain. My P0014 was just that.
This slack caused the phaser to be out just enough.
chaosdsm
Oct 25, 2022 09:47 PM
LadyBee
May 7, 2019 12:08 AM
FARMBOY1938
Jul 20, 2015 10:28 PM
calli4120
Oct 17, 2013 08:55 AM
axxsys
Jul 30, 2013 09:50 AM
