Fuel Injector Pressure sensor location
Old May 13, 2023 | 09:17 PM
I can't seem to find a part number for the 2.2 bolt. Sorry, like donbrew said, wrecking yard or dealer.
Old Jun 8, 2023 | 10:20 AM
PulpFriction's Avatar
With full knowledge that the original post is a bit old, for the benefit of future readers, OP was barking up the wrong tree. P0090 is a problem with the regulator, not the sensor.
Never dealt with this but isn’t the regulator integral with the high pressure fuel pump? The first action would be to check the wires and plug to the HPFP of course but the problem may be the HPFP.
Old Jun 8, 2023 | 11:55 AM
He had just replaced the HPFP, so perhaps a pin got bent or pushed out of the connector.
But the sensor is a possible cause, from obd-codes.com
Potential causes for this code to set are:
Shorted or open wiring and/or connectors in the fuel pressure. regulator control circuit
Defective fuel pressure regulator
Faulty fuel rail pressure sensor
Bad PCM or a PCM programming error
Read more at: https://www.obd-codes.com/p0090
Copyright OBD-Codes.com
Old Jun 8, 2023 | 06:48 PM
Chevcat never came back to confirm what fixed his P0090 code. Since Oct 2021. Thread closed
graydog
Aug 10, 2015 09:23 PM
Fievel4
Fuel Economy - Hypermiling
Jan 5, 2015 03:42 PM
tim75901
Feb 26, 2014 08:59 PM
car nut
Dec 3, 2013 06:32 PM
Chmp64
Nov 21, 2013 07:55 PM
