Lots of oil in cyl #3
Old Feb 21, 2020 | 03:52 AM
  #111
Cat Man HHR's Avatar
What's with the red paint on the top of the lense ?
Old Feb 21, 2020 | 07:09 AM
  #112
Kinda an eyebrow, note how the inside of the headlights are also painted red.
Old Feb 21, 2020 | 07:12 AM
  #113
Search Headlight Eyelids.
Old Feb 21, 2020 | 07:16 AM
  #114
Old Feb 21, 2020 | 12:22 PM
  #115
To each their own.
Old Feb 22, 2020 | 02:48 PM
  #116
Dark_Knight's Avatar
To each their own.
not sure that's how I got the car. It looks to be done by spray can and has shrunk and cracked. Not my style. But once i can I'll buy new headlight assemblies.
Old Feb 22, 2020 | 04:47 PM
  #117
Thanks Dark Knight, as it's not my style also.
Looks like something somebody did in a dark alley.
Old Feb 24, 2020 | 05:19 PM
  #118
Ok so I gotta replace the the cam solenoid. And there's a issue with the electric steering. Says possible 4 amp fuse or the computer connection. Iv done a search on this and either I'm dumb or there's nothing. Any ideas?
wheel bearing is in.
Old Feb 24, 2020 | 05:52 PM
  #119
Which cam solenoid , I recommend replacing both the intake and exhaust
the code would help determine which one is the problem.
I just replaced both after code P0014.
As for the electric power steering motor , double check the connection on the underhood fuse box at the left rear, that’s the power wire to the motor
That connection to the right of the brake master cylinder
Old Feb 24, 2020 | 06:04 PM
  #120
if you refuting to the connection I have circled? I have cleaned it at the time of engine install.
i have heard something about some fuses. Do you know anything about this?
iv also heard about some extended warranty for the power steering but all the facts kinda cancel it out due to posted fact being all over the place.
