SS Overheating
Old Jan 11, 2017 | 08:44 PM
bourbonslurp's Avatar
Question SS Overheating
'09 SS, 116K+
I've spent a couple of hours sifting through the previous threads on the subject.
My question is, does anyone have a make, model, brand, etc. for just the fan motor by itself? Even though GM doesn't have a part no. listed for that individual part, I'm sure our cars can't be the only ones in existence that use that same motor.
I've already tried replacing the control module, but I'm still having the issue where the cooling fan runs "some times". I'm thinking the motor is the issue. I'm just trying to avoid buying the whole assembly when I already have a new control module.
Thx.
Old Jan 11, 2017 | 10:18 PM
I don't have the part number but...
You might want to take a close look at the wiring in the vicinity of the fan. I recall a couple threads from way back. I recall that one owner found a burnt or bad spot in the harness several inches back from the fan connection.
I believe there is some sort of crimp connection in that location.
Old Jan 11, 2017 | 10:38 PM
Thank you for the reply.
I recall that from some of the threads I've read, but I'll have to wait for daylight before I can take a closer look. I also read a lot of your posts in those previous threads. Your input is much appreciated.
Old Jan 11, 2017 | 10:44 PM
A couple years ago, I ran in to the issue where the parts catalogs would list one part no. for an entire assembly for a couple of model years, then list individual part no. on a couple of other model years. (power steering motor on a LS)
I also plan to poke around the Cobalt forums a bit.
cmelvin531
Oct 27, 2018 04:43 PM
TxSkyPilot
Jan 28, 2008 04:54 PM
TX-HHR
Apr 16, 2007 08:45 PM
bandit12
Feb 18, 2007 11:58 PM
fantomfreke
Oct 9, 2006 10:56 PM
