2008 hhr horrible tread wear on rear
Old Feb 16, 2014 | 07:08 PM
Try this thread also: https://www.chevyhhr.net/forums/problems-service-repairs-42/front-end-alignment-specs-43816/
The link above, posted by 843de is kind of odd and older. It shows the correct specs but shows a FE0, FE2 suspensions(??)
(No offense meant Mike)
Old Feb 16, 2014 | 07:13 PM
No offense taken, just noticed the odd suspension codes myself, good job on digging up the other thread.
To the OP, what sort of tire rotation schedule and pattern are you using?
Old Feb 16, 2014 | 09:23 PM
If the wear is on the inside, for sure hubs. If you park uphill and walk up behind the car you will probably notice the wheels are canted, (top closer to the car, bottom out). / \
If they are also bumpy, same thing.
Jack a rear wheel up and push-pull on it, any play that you can feel is unacceptable. Or, have someone who owns a runout gauge check the end play .005 inch is the max.
Unless you hit something really hard, the rear does not get aligned even though it is possible to do it.
Franco Fanfuria
Aug 28, 2014 08:22 PM
MarkD13
Tires & Wheels
Mar 8, 2013 05:09 PM
Neal Sweeney
May 21, 2010 06:31 PM
wonderwouldyou
Aug 22, 2009 07:41 PM
