tire size help 225-50-17 fitment
Old Sep 28, 2011 | 08:07 PM
vtfb68's Avatar
H.R.,
I run 225/50/17 on the front and 245/45/17 on the rear with stock LT wheels, Goldline springs all around. I have had no issues at all. The tires are the same height but the rear is wider. I had to use Kumho tires so the two sizes would have the same tread pattern.
It adds a more muscle look. hope this helps, good luck.
Victor
Old Sep 28, 2011 | 08:12 PM
I've been wanting to try the same with the wider rears......
Old Sep 28, 2011 | 09:13 PM
Bob Cavicchio's Avatar
I get much better performance as the Goodyear is a much better tire than the Firecr@p it came with. A 17" tire will always feel a little "stiff" as there's not a ton of sidewall there, say as there is on a 16" with the same diameter. The 225 measurement mostly gives you a wider tire.... not a taller one, and you won't be able to go much taller than this 225/50R17.
Should not effect warranty.... if somebody says it does, I'd try another dealer. Beware, some of these dealers try void your warranty for anything..... like, you know, air-fresheners and such.....
Thanks
Blue Beast (aka Boydie)
Tires & Wheels
Mar 6, 2015 11:35 AM
jd0225
Tires & Wheels
Nov 27, 2013 05:20 PM
07azhhr
Tires & Wheels
23
Nov 2, 2012 03:52 PM
JazzDad
Tires & Wheels
21
Oct 16, 2012 11:38 AM
mmont50
Tires & Wheels
20
Sep 13, 2012 11:57 PM
