Best mods for engine perforemaance HHR SS
Old Dec 20, 2012 | 11:11 AM
Nah, I will cut it open and seal it to the hole in the hood, when it's done.
Old Dec 20, 2012 | 11:34 AM
Omnigear's Avatar
Powell raceshop rotated mounts to Put the power down
A great tune
Cai,ic pipes and a ic
Depends on your budget
Old Dec 20, 2012 | 07:50 PM
motogumby's Avatar
Thanks guys, i will follow your advise
Old Dec 21, 2012 | 11:40 AM
Miltown SS's Avatar
Best bang for your buck would be a tune and a catless downpipe. Charge pipes wouldn't hurt either. You will love the sound with a catless downpipe...mellow while cruising and then WAAAHHHHH WAAAHHHH when you step on it.
Old Oct 15, 2015 | 07:13 PM
Cat Man HHR's Avatar
Originally Posted by 2005HHRauto
Step1
Modifying the stock DP, is all that is needed to remove the 'restriction', of the stock exhaust system.
Using an 18" piece of 2.75" tubing, with slight pressure, move the tubing, side to side, to 'core' a hole thru the 2nd cat.
This leaves some of the cat guts, which will stay in place, & will get hot like a normal cat, so if an inspector feels the outside of the cat, it feels like a normal cat.
It will pass emission testing also.
That 1st cat is really important, to keep the intake tract/piping, 'charged', which keeps torque at the highest level, for DD, at low, non-boosted RPMs.
Hay, it works for me.
I've tried different high flow cat/cat less DPs, & none keep the low end torque high, like the modded stock DP.
Step2
Add a K&N intake tube & filter. , to remove the intake restriction.
Step3
Add a Turbo-Tech engine mount. , to 'plant' the power.
Step 4....Tune it Any tune will do , GMPP, Trifecta, HPTuner.
Now you have a muscle car, that will run in the 13s, all day long.
Just add a E47.5 tune / slicks, & run in the 12s, all day long.
It's so easy to make these buggys go...
I haven't done Step 1 yet, but now knowing how it's explained, will get to it.
Step 2 All I did was buy the K&N intake pipe/fitting from K&N and use my OEM filter and air box. Tough a true ram air system would be nice to help.
Step 3 Bought the TTR upper engine mount.
Step 4 Have a Trifector tune, I guess after doing the "cat gut" thing I should do a data log and upgrade my tune.
Slicks? What size and compound would be helpful. Temperature/track conditions would add into the equation.
xzombiex66
Jun 24, 2021 11:39 PM
ragtop
2.4L Performance Tech
Dec 8, 2013 12:49 AM
shirer61
2.2L Performance Tech
14
Mar 2, 2012 02:25 PM
menance
Dec 22, 2010 06:14 PM
Scrivs
Aug 29, 2008 09:45 PM
