Aluminum Coolant Tube
Old Apr 22, 2020 | 01:21 PM
Would removing the tube and applying a big hammer do the job?
Old Apr 22, 2020 | 02:37 PM
Calebs0615's Avatar
If you mean self clearance the runner on the header I probably could do that. Buuutt I don't really want to ruin my shiny new header.. I was just looking at it and mine also has the tab. So im going to wrap it with that performance fiber wrap stuff. Like I said ill keep everyone updated if something bad happens.. 😆 I appreciate everybodys input.
Old Apr 22, 2020 | 02:43 PM
If you have a dremel, or something like, you could probably enlarge the top of the slot, so the tab could move a little more.
You could also get a ceramic coating on the header. Reduce heat output, and keep it pretty for longer.
Old Apr 22, 2020 | 02:50 PM
Calebs0615's Avatar
Im not confident enough... And hmmm... Do you have any idea who would do that? Like what sort of shop?
Old Apr 22, 2020 | 03:08 PM
Maybe a muffler shop.
Old Apr 22, 2020 | 03:13 PM
  #26
I meant take a BFH to the transfer tube. IIRC there is a flat spot already.
Old Apr 22, 2020 | 03:34 PM
  #27
Calebs0615's Avatar
Id be afraid id put a crack in it..
Old Apr 22, 2020 | 03:44 PM
  #28
I didn't see a flat spot. I would be worried about damaging the seals.
You can get a dremel, or Roto-zip, or some other multi-tool at Harbor Freight for cheap. It's just a thin rib of aluminum.
Have someone help you get the hood off, and crawl over the passenger fender. If you can get in a position to do it, I would think it would be about a 1 minute job.
Old Apr 22, 2020 | 03:48 PM
  #29
No mention of any of the dremel surgery in the thread you posted RJ.
I suggest you simply follow the small adjustment and then see if more drastic measures are required.
Old Apr 22, 2020 | 03:51 PM
  #30
Calebs0615's Avatar
Maybe ill try that. I have a dremel tool i got from harbor freight a while back. Are you talking about that aluminum tab you can see? Shave that back?
