Header blowing gaskets
Old Sep 4, 2015 | 08:04 PM
Joepoppa1's Avatar
I slapped the stock one on there that had the little metal donut on it. It was the same size as this last crappy one and it was free. It sounds like it sealed ok, but we will see after a week.
Old Sep 4, 2015 | 08:06 PM
Fingers crossed!
Old Sep 4, 2015 | 08:35 PM
Joepoppa1's Avatar
Originally Posted by Oldblue
Fingers crossed!
yeah, it sounds good now. I posted that vid on the other thread, but here it is.
http://vid253.photobucket.com/albums...psatwcngyn.mp4
Old Sep 4, 2015 | 08:36 PM
Sounds good for 19 seconds.
Old Sep 5, 2015 | 11:09 AM
Blue_SS's Avatar
It sounds like you might have fixed it while I was away, but when I had a non-stock, pieced together system on my last car, this (below, in bold) was what I had to do. Local independent parts place let me bring my parts into the back room, and find something that worked. You don't want gasket material covering part of the hole. If it doesn't cover the whole flange, on the other hand, you could be all set.
Originally Posted by donbrew
Well! the new header has an oval hole, the old downpipe has a round hole. Do you think a gasket with a round hole would work? Did you put the gasket up against BOTH pieces for fit?
I would try one of the "generic" gaskets that are much larger than the flanges, but fit the bolt holes and the center hole.
The other possibility is that the bolts/nuts are not fully engaging and pulling the parts tight. I had that problem with an after market downpipe that had a thinner flange plate; they could not be tightened any further, but they were not tight enough. Washers fixed it.
Old Sep 6, 2015 | 07:17 PM
RF2's Avatar
RF2
I have tried many headers on my car and found out some are good and bad. What you are finding out is a out of round problem on the collector flange. Here is a pic of two headers from two manufacturers. You can guess which one leaked. If the hole is not round and inside of he gasket it wont seal.
I had to weld the hole on the collector flange and re machine it to work. It is a back up now.
RBodeman
Mar 31, 2012 06:28 PM
zeebo271
Aug 30, 2007 05:56 AM
jimshhr
Nov 16, 2005 07:35 AM
