P0016 - changed 2 years ago
Old May 6, 2022 | 04:20 PM
  #31
PulpFriction's Avatar
Originally Posted by kjingram821
So there's nothing broken, I'm not sure if the tensioner failed or if it's because the bolt on the tensioner guide had wiggled itself just slightly loose. All bolts were torqued to spec when we did this job 2 years ago, so I'm going to investigate the threads and bolt this evening. It definitely was one link off, and did slap the top guide when rotating the engine clockwise manually.[size=33px]
[/size]
By “slap the top guide” do you mean the chain was loose? Because it should be pretty snug. If everything else was intact and the chain was loose and/or had jumped, that suggests that the tensioner had not done its job.
Old May 7, 2022 | 07:57 AM
  #32
I remove the t stat to engine housing and then the pipe, I leave the heater hoses alone. If your thermostat to rad hose housing has that blank capped off , I replaced the housing with one from a 2007 2.2, no extra port to cap off!
Old May 9, 2022 | 08:18 AM
  #33
kjingram821's Avatar
Correct, it was loose, I think on the of two camshafts jumped a tooth allowing a little slack between them.
This is what I did as well, left all the heater hoses, it wasn't as bad getting the T-stat to engine housing back in as I thought it might be. 20 or 30 scrapes on the forearm later, lol.
It's all back together and running like a top. The Cloyes exhaust balance chain sprocket did not want to fit on the balance shaft no matter what, so I left all OEM balance shaft gears. It looks like the flat spot/key wasn't cut exactly right on the back of the gear.
Graham Konrad
Dec 17, 2021 12:57 PM
Charleenatas
2.0L Performance Tech
45
Dec 21, 2020 11:03 AM
JApow1865
Sep 22, 2020 08:12 PM
Muddie
2.2L Performance Tech
18
Nov 25, 2016 06:23 PM
Danman03
May 12, 2016 04:08 PM
