VVT Codes P0016 & P0017 HELP!!!
Old Feb 28, 2019 | 09:59 PM
thelastplace's Avatar
Read again. The first thing I say is 'timing chain' and it was all done by a ASE certified mechanic. Total cost was $912.73
Old Mar 1, 2019 | 07:55 AM
Sorry, that is what those 2 codes mean.
Old Mar 1, 2019 | 08:11 AM
Yes, I re read the post, but what parts did he use?
Im sorry to report that some places use the $35.00 kits from flea bay and charge you a lot more!
those codes indicate the timing chain. Stretched and skipped a tooth.
Old Mar 1, 2019 | 02:21 PM
Cat Man HHR's Avatar
Joe
I know you have 22K since the repair. If these codes lean to a chain problem I would have someone pull the valve cover and see if something isn't correct.
If curious ask the people what brand/company they used for the chain kit. Or if they did use a kit at all.
Old Mar 1, 2019 | 04:33 PM
For my money this 9-4201SX is the kit for your 2.4 VVT Ecotec timing chain , no gears for the camshafts, because they are different
This is the balance shaft kit 9-4202s
this is the important piece, it replaces the weak little bolt under the plug in the head
preventing this
Old Mar 2, 2019 | 01:36 AM
Short video for the P0016 and P0017
I also did some reading and those two codes show the sensors are working correctly. When the two sensors ( intake and exhaust cam positions) don't agree to what's going on the two codes are triggered.
tlink211
Jul 9, 2018 06:11 PM
m_ridzon
Aug 11, 2017 06:53 PM
Jimmy68
2.2L Performance Tech
13
Aug 1, 2016 02:06 PM
swangelica
Aug 7, 2012 04:42 PM
