Front Sway Bar Diameter
Old Jun 27, 2017 | 11:21 AM
I just wanted to confirm they are in a package of two
Like this
Old Jun 27, 2017 | 11:59 AM
m_ridzon's Avatar
Like this
Spot-On! You're exactly right. Pack of 2.
The shafts of them are threaded with 7/16-20 thread. Buy a piece of threaded rod as well as some coupling nuts and some jam nuts to lengthen them. Then you'll be up and running!
M Ridzon
Old Oct 31, 2017 | 03:04 PM
m_ridzon's Avatar
Update: I've been driving with the Energy Suspension sway bar end links for a few months now. After a few months, they started squeaking like crazy. I called Energy Suspension. It turns out that the ball-n-socket joints need greased from time to time. From what I'm told, polyurethane is notorious for squeaking anyplace it touches moving metal; thus it needs lubed. Although it is superior to rubber in terms of suspension performance, I guess it has a drawback. He said the ones I installed (#9.8171) pop right apart with a little force (i.e., the ball pops out of the socket). You then apply some chassis grease to the ball-n-socket and pop them back together.
They said they have a proprietary lube for sale that is meant for this and is supposedly superior in terms of water resistance and wash-out. I am going to try ordinary chassis grease first to see how it does before I shell out cash to buy "special" grease. I figure if cheap chassis grease means I only have to do it once a year, then I'm fine with that small hassle.
I wanted to circle back and let folks know this since I think somebody was considering buying them on here.
Thanks,
M Ridzon
Old Oct 31, 2017 | 06:23 PM
White lithium grease or silicone grease like brake pad grease would be better
Old Feb 17, 2018 | 05:34 PM
m_ridzon's Avatar
I finally got a chance to disassemble the Energy Suspension sway bar end links today. I found them bone dry, hence the squeaking/rubbing noise. I packed the sockets full of silicone lubricant and reassembled. We'll see how it goes now. Hopefully they stay quiet for a good long time!
Gary Perkinson
Feb 25, 2014 09:04 AM
kornellred
26
Apr 11, 2012 09:15 AM
foofoomaru
Tires & Wheels
11
Feb 8, 2012 05:24 AM
bassbase
Mods - Engine/Exhaust
Jul 17, 2011 12:11 PM
sgtsteve
Aug 10, 2009 09:50 AM
