Upgrading Suspension
Old Mar 26, 2015 | 12:37 PM
LT1GMC's Avatar
Originally Posted by donbrew
Only if you have installed a camber kit or drilled out the holes in the struts!
The ONLY available adjustment on a STOCK HHR is toe.
Not to be argumentative, but perhaps you should read the Chevrolet Service manual, as I did. There is room for movement in those holes versus the bolts.
Old Mar 26, 2015 | 02:43 PM
Perhaps you should get under the car and try it. As I have, at least six times.
The rest of the instructions say to remove the strut and drill the holes.
Old Mar 26, 2015 | 02:54 PM
Oh, maybe using smaller diameter bolts would work, and give some leeway, as the stock ones sure don't. (really people, do not try that..... really, please don't - that would be totally unsafe).
Old Mar 26, 2015 | 05:17 PM
Note the double layer on the connection area, one hole is larger than the other. That is to give a gauge for the drilling.
Note the knurled end of the bolt is not a force fit, but there is very little play. There is more play on the threaded end, but less than a 64th and that's only one side.
The bolt is a force fit on the knurled end into the steering knuckle.
That is a "from the factory" strut and bolt.
Old Mar 26, 2015 | 05:33 PM
Point to Donbrew!, LT1GMC the ball is in your court, it's your serve!
gio89kid
Apr 20, 2014 07:29 AM
JMichael
Oct 23, 2012 05:19 PM
8thmileman
Jun 22, 2012 10:28 AM
barfan1
Mar 26, 2012 02:03 AM
wxman
Jun 30, 2008 10:35 PM
